jands hog 500
can you use shape create in a jands hog 500
thanks dano
  • You can use it to create effects for the Hog, not specifically use in it. You will have to first create the effect on a PC where then you can save it onto you show floppy. Open it up and I am not exactly sure the file name but put that effects text file. Save it and load that show on the Hog. I think it should work... I have never done it. But I am guessing that it is similar to adding a new library file. I also think you might have to export it to some other software.. FX gen or something like that.
