hi i have hog 1000 :hogsign: and today i got a big big problem, then i try to record a cue in my show i have a error message " RAN OUT OF EFFECT MEMORY" I have HOG 1000 whit 2MB memory please help
hi toady its happen again, but its more serious problem i got new show at 21 and now i try prepare for it but i stuck in programing!!!!! i have this message (see photo lh4.googleusercontent.com/-8nPi4uPIQyw/Tr5H6ldPSvI/AAAAAAAAFKg/hx_1ahbWwFE/s1440/IMG_1770.JPG ) i try delete every thing what i don't use at (page, effect, grope, position, beam, everything) but its doesn't help!!!!!!! after this message the console do not store any parameter!!! im erase all another Qs i have only one it around 80 scene
On Hog II family consoles (Including the Hog 1000), best practices call for you to do a deep clear at least once a day when you've been programming. Save several copies of the show to disk then do the clear because it will erase your showfile from the console.
If you go too long without doing a deep clear you can end up with flaky problems like what you're describing.
I did it , but after clean start I have same problem!!! It do not help! I try it couple times! And same problem After load show try record any Q I have it problem! I try update softwear to 3.3 (177) same problem
There may not be a lot you can do then other than going back to an older backup before the problem occurs. Is it an effect heavy show?
It's probably still worth dropping an email to support and see if they have any suggestions. A few of the folks in support have a lot more experience with the Hog2 family consoles than I do.
I'm got reason of this problem by my self!!!!! It's was overload memory for effects, I just clear "list" from lists that I do not use!!!! And now everything works fine!!!!
