Profiles wont work on Hog 1000
Im tring to get a profile to work on my hog 1000 but it keeps giving me an error. It also says The file is incompatible with this version of the software. Load has aborted.
_lib.lib: range = 41, 50, fans normal, noauto
here is the code below:
fixture = Batten Tour
manufacturer = 99
product = 1
name = Batten Tour
output = dmx
parameter = Intensity
default = 0
highlight = 255
crossfade = 0
type = htp8bit
range = 0, 255, %
parameter = Red
default = 0
highlight = 255
crossfade = 0
type = ltp8bit
range = 0, 255, %
parameter = Green
default = 0
highlight = 255
crossfade = 0
type = ltp8bit
range = 0, 255, %
parameter = Blue
default = 0
highlight = 255
crossfade = 0
type = ltp8bit
range = 0, 255, %
parameter = White
default = 0
highlight = 255
crossfade = 0
type = ltp8bit
range = 0, 255, %
parameter = Amber
default = 0
highlight = 255
crossfade = 0
type = ltp8bit
range = 0, 255, %
parameter = Macro
default = 0
highlight = 0
crossfade = 0
type = ltp8bit
range = 0, 200, noauto
range = 201, 205, 3200K, centre
range = 206, 210, 3400K, centre
range = 211, 215, 4200K, centre
range = 216, 220, 4900K, centre
range = 221, 225, 5600K, centre
range = 226, 230, 5900K, centre
range = 231, 235, 6500K, centre
range = 236, 240, 7200K, centre
range = 241, 245, 8000K, centre
range = 246, 250, 8500K, centre
range = 251, 255, 10000K, centre
parameter = Strobe
default = 0
highlight = 0
crossfade = 0
type = ltp8bit
range = 0, 255, %
parameter = Auto
default = 0
highlight = 0
crossfade = 0
type = ltp8bit
range = 0, 10, no function, noauto
range = 11, 20, fans off, noauto
range = 21, 30, fans low, noauto
range = 31, 40, fans normal, noauto
range = 41, 50, fans high, noauto
range = 51, 60, fans auto, noauto
range = 61, 70, auto1, noauto
range = 71, 80, auto2, noauto
range = 81, 90, auto3, noauto
range = 91, 100, auto4, noauto
range = 101, 110, auto5, noauto
range = 111, 120, auto6, noauto
range = 121, 130, auto7, noauto
range = 131, 140, auto8, noauto
range = 141, 150, auto9, noauto
range = 151, 160, auto10, noauto
range = 161, 170, custom1, noauto
range = 171, 180, custom2, noauto
range = 181, 190, custom3, noauto
range = 191, 200, custom4, noauto
range = 201, 210, custom5, noauto
range = 211, 220, custom6, noauto
range = 221, 230, custom7, noauto
range = 231, 240, custom8, noauto
range = 241, 250, custom9, noauto
range = 251, 255, custom10, noauto
parameter = Auto Speed
default = 0
highlight = 0
crossfade = 0
type = ltp8bit
range = 0, 255, %
parameter = Dimmer Speed
default = 19
highlight = 19
crossfade = 0
type = ltp8bit
range = 0, 9, dimmer speed, noauto
range = 10, 29, linear
range = 30, 69, non-linear 1, noauto
range = 70, 129, non-linear 2, noauto
range = 130, 189, non-linear 3, noauto
range = 190, 255, non-linear 4, noauto
parameter = ID Address
default = 0
highlight = 0
crossfade = 0
type = ltp8bit
range = 0, 9, All ID's, noauto
range = 10, 19, ID 1, noauto
range = 20, 29, ID 2, noauto
range = 30, 39, ID 3, noauto
range = 40, 49, ID 4, noauto
range = 50, 59, ID 5, noauto
range = 60, 69, ID 6, noauto
range = 70, 79, ID 7, noauto
range = 80, 89, ID 8, noauto
range = 90, 99, ID 9, noauto
range = 100, 109, ID 10, noauto
range = 110, 119, ID 11, noauto
range = 120, 129, ID 12, noauto
range = 130, 139, ID 13, noauto
range = 140, 149, ID 14, noauto
range = 150, 159, ID 15, noauto
range = 160, 169, ID 16, noauto
range = 170, 179, ID 17, noauto
range = 180, 189, ID 18, noauto
range = 190, 199, ID 19, noauto
range = 200, 209, ID 20, noauto
range = 210, ID 21, noauto
range = 211, ID 22, noauto
range = 212, ID 23, noauto
range = 213, ID 24, noauto
range = 214, ID 25, noauto
range = 215, ID 26, noauto
range = 216, ID 27, noauto
range = 217, ID 28, noauto
range = 218, ID 29, noauto
range = 219, ID 30, noauto
range = 220, ID 31, noauto
range = 221, ID 32, noauto
range = 222, ID 33, noauto
range = 223, ID 34, noauto
range = 224, ID 35, noauto
range = 225, ID 36, noauto
range = 226, ID 37, noauto
range = 227, ID 38, noauto
range = 228, ID 39, noauto
range = 229, ID 40, noauto
range = 230, ID 41, noauto
range = 231, ID 42, noauto
range = 232, ID 43, noauto
range = 233, ID 44, noauto
range = 234, ID 45, noauto
range = 235, ID 46, noauto
range = 236, ID 47, noauto
range = 237, ID 48, noauto
range = 238, ID 49, noauto
range = 239, ID 50, noauto
range = 240, ID 51, noauto
range = 241, ID 52, noauto
range = 242, ID 53, noauto
range = 243, ID 54, noauto
range = 244, ID 55, noauto
range = 245, ID 56, noauto
range = 246, ID 57, noauto
range = 247, ID 58, noauto
range = 248, ID 59, noauto
range = 249, ID 60, noauto
range = 250, ID 61, noauto
range = 251, ID 62, noauto
range = 252, ID 63, noauto
range = 253, ID 64, noauto
range = 254, ID 65, noauto
range = 255, ID 66, noauto
parameter = Block Selection
default = 0
highlight = 0
crossfade = 0
type = ltp8bit
range = 0, 4, blocks 123, centre
range = 5, 34, block 1, centre
range = 35, 64, block 2, centre
range = 65, 94, block 3, centre
range = 95, 124, block 1&2, centre
range = 125, 154, block 2&3, centre
range = 155, 184, block 1&3, centre
range = 185, 214, blocks 123, centre, noauto
range = 215, 255, nofunction, noauto
Any and all help would be appreciated.
