Another Hog 500 Fixture Problem
Hey Everyone, trying to load fixture profiles into a Hog 500. Last night I was able to get each profile to load individually, but as soon as I appended multiple profiles the console would throw up an error regarding missing parameters.
Today, the console has decided that it doesn't want to load any profiles whatsoever.
I've made a fresh show file from the console, and edited the _lib.lib file in not pad, I've tried all manner of version numbers, manufacturer and product codes, I've generated the files multiple times in the fixture generator. I'm hoping somebody can spot an issue in my profile, otherwise this console is going back.
Anywho, profile as it stands right now is in the next post. Any help would be much appreciated.
Edit: Console is running last software build, that was one of the first things I checked. I've tried multiple different floppy disks, in different computers (ranging from Windows Vista to Windows 8).
  • version = 40
    count = 2
    fixture = StagePar
    manufacturer = 0
    product = 101
    name = MicrohStagePARV2
    yoke = no
    //Created using Denis Hessberger's Wholehog2 Library Generator application!
    output = dmx
    parameter = Intensity
    default = 0
    highlight = 0
    crossfade = 0
    movement = normal
    type = ltp8bit
    range = 0, 255,%
    parameter = Red
    default = 0
    highlight = 0
    crossfade = 0
    movement = normal
    type = ltp8bit
    range = 0, 255,%
    parameter = Green
    default = 0
    highlight = 0
    crossfade = 0
    movement = normal
    type = ltp8bit
    range = 0, 255,%
    parameter = Blue
    default = 0
    highlight = 0
    crossfade = 0
    movement = normal
    type = ltp8bit
    range = 0, 255,%
    parameter = Strobe
    kind = b
    default = 0
    highlight = 0
    crossfade = 0
    movement = normal
    type = ltp8bit
    range = 0, 9,NoStrobe, noauto
    range = 10, 57,Strobe, noauto
    range = 58, 59,NoStrobe, noauto
    range = 60, 108,PulseOff, noauto
    range = 109, 110,NoStrobe, noauto
    range = 111, 159,PulseOn, noauto
    range = 160, 161,NoStrobe, noauto
    range = 162, 255,Random, noauto
    constant = 0
    fixture = BladeP9
    manufacturer = 0
    product = 100
    name = MicroBladeP9Q
    yoke = no
    output = dmx
    parameter = Red
    default = 0
    highlight = 0
    crossfade = 0
    movement = normal
    type = ltp8bit
    range = 0, 255,%
    parameter = Green
    default = 0
    highlight = 0
    crossfade = 0
    movement = normal
    type = ltp8bit
    range = 0, 255,%
    parameter = Blue
    default = 0
    highlight = 0
    crossfade = 0
    movement = normal
    type = ltp8bit
    range = 0, 255,%
    kind = c
    default = 0
    highlight = 0
    crossfade = 0
    movement = normal
    type = ltp8bit
    range = 0, 255,%
    parameter = Strobe
    default = 0
    highlight = 15
    crossfade = 0
    movement = normal
    type = ltp8bit
    range = 0, 14,NoStrobe, noauto
    range = 15, 29,Strobe, noauto
    range = 30, 255, derp, noauto
    constant = 0
    constant = 0
    parameter = Speed
    default = 0
    highlight = 0
    crossfade = 0
    movement = normal
    type = ltp8bit
    range = 0, 255,%
  • What's the error message of the console while loading the show-file with your personal _lib.lib file?
    On the first view it all looks good and should work.
  • salve ho bisogno di avere le fixture aggiornate per la Hog 500. Grazie
