Can't get XYZ to work
I've got a Hog 1000 and I'm trying to get the XYZ function to work. I feel like I've done everything correctly but when I hit Position more than once it never flips to XYZ coordinates.
I created the 4 position palettes, hit set twice to set them as the 4 cal points. I then hit select and calibrate, the consoles chews on it for a bit and then it says complete.
I then select some of my lights, hit position twice but all I ever get is Intensity, Pan and Tilt.
Is there something special like XYZ is restricted to only certain kinds of fixtures?
