copy cue 1>
i would like to use syntax copy cue 1 thru to... like mac 600 1 thru... enter ...but this gives me red syntax..
  • Matt,
    As I explained in another thread, the syntax for copy on the WHolehog 3 is "source Comamnd destination". Please take a look at page 86 of the current manual for a full description.
    Even with the correct syntax, the "source copy thru (unspecified)" is not currently valid. You need to add an end to the command. I will look into the possibility of allowing an open ended selection.
  • thanks for explaining, i know the syntax, allways a bit tricky to be switching HOG II and III all the time.
