Tip #4 - USB cables w/ LEDs
Whenever I'm using any USB device with either of the HOG-PCs or my HOG-3, I always connect them with one of those fancy looking USB cables that has an LED at either end (I buy the blue ones to match the FPS gear, but they come in a variety of colors)
This is not strictly a vanity thing, although it does look really slick:cool: .
It is also useful in troubleshooting connctions. If the lights are on, you know the cable is probably connected properly and can check something else.
You should be able to find these cables at any good computer supply store or check out this link:
www.cdw.com/shop/products/default.aspx?EDC=523778
