Hey Tom,
I sent you the show file I am currently working on. On Master 10 I have 141 Birket Strobes that play back rather fast. A bunch of Cues are creating patterns with delays. When I play them back manually they work great. If I do it by Time code they will not play back correctly.
I have figured out if I remove all the cues that are using the Effects generator they work fine. All the Effects generated cues are creating a random strobe effect.
Can you take a look and let me know what you think?
Also what's the difference between Sine can Cosine? I notice the WH3 doesn't have Cosine and I was using it on some moving fixtures with the WH2. Will Sine do the same thing?
Thanks, Doug :cool:
