Offset/Rate/Size on VM's
I try all the time to record only an Offset/Rate/Size value's into a Virtual Master and i can't make it work.
What i trying to do is to record a diffrent values of offset or Rate to a VM for change any exiting EFX without changing the Table of the EFX for a quick live show's.
For example, i want VM34 will be an offset 0'>180' of the INT Efx's, so i can record a simple Chaser Efx with 0' offset and any time i press on VM34 the offset become to 0'>180' and the time i release this VM34 the offset back to its original value 0' .
Is this possible ???
Amir
Danix.co.il
Israel
