Okey Dokey folks,
It seems as if I've been asked a lot lately for preferences files that have a more logical wheelset order. So I'm making my own personal prefs available to anyone who wants them.  I use two different settings, one for programming (PGM) and one for actual show runs (RUN).
Make sure to read the Readme.txt file BEFORE you use these files!
So here we go...URL is at the end of this post.
I've incorporated the DL-2 wheelsets that are already posted on the FPS site into my preferences files.
PLEASE READ THIS FIRST!!
WARNING!!
I can not and will not take responsibility for any and all damages these files may cause to your show!
Make sure you have backed-up ALL show data both on external and internal media!!
I STRONGLY encourage you to Export pre-existing prefs so you can restore them if this causes you problems.
You will have to restore any changes you made prior to any Imports!!
Importing preferences is NOT REVERSABLE!!
You CANNOT "Undo" Imports without a prior copy of your prefs!
If you don't know what you're doing...DO NOT DO THIS!!
www.retinalresonance.com/H3prefs.html
:friday:
