dmx rate
Due to a couple of older fixtures which are for one reason or another upset by the dmx from the console the effective solution has required the dmx rate to be reduced down to something like 15Hz. The downside is that this change is applied to the whole DP. Can an enhancement be logged to enable single dmx streams to be run at individual rates?
Thanks Ross
