I was wondering if there is any possibility of adding an Undo window. I find it helpful if we can look into the window and jump back to the point we want to undo/redo instead of press undo/redo and not being sure of whether have we come to the correct point. It doesn't have to show all history but at least show the last command to preivous 20. Then using Open + Undo to bring out the window. Just some ideas. Thank you.
