Timing to Parameters Request
I was thinking of a way to edit parameter timings when recording cues and editing without going into the spreadsheet views.
WHAT IF... you change some parameters, then do some sort of key combo with 'Time' allowing you to select the different parameters you just changed, then bring up the standard time parameters ('Fade in', 'Fade out', 'Delay in', 'Delay out') on the encoder wheels so you can set those times for the selected parameters.
