Hue Problem
Hi there
I still have some problem withe the HUE and SATURATION Parameter.
If i make a effect on the HUE with a size bigger than 360, the fixtures change the colour to white!
If i change the SATURATION to 0% the ML don't go to a absolut white.
Regards
Hg
  • Hg,
    I've logged bug #10517 for your problem with fixtures outputting white when a hue effect with a size >360 is played.
    The reason that fixtures don't output CMY 0/0/0 when saturation is at 0 is because the HS colour space is calibrated. There is a set white point and all calibrated fixtures will try to match that white point. You should check your HS white point and make sure that it is set approrpriately. Arc fixtures will come closer to CMY 0/0/0 if the HS white point is set to Arc.
    I hope this helps.
