Lag in running cues from list direcory
Hey Everyone
Whenever I execute a cue list from my list directory, I have a noticable time from between I touch the list and when I see any output on stage (or in the output window). This even happens when I with a 0s fade time.
Is this normal? Is there any way to work around it?
Adam
  • Hey Adam,
    I would say that this is not normal. Lists are generally very responsive to presses in the list directory. If you move your lists to a master do they respond any better with the go button?
    Software version Version 2.1 was released today and I would recomend trying the upgrade to see if responsiveness improves for you. If the list directory still seems sluggish then we will dig further.
