Networked Printer
So, im sure this has been discussed, but . . .
I'm about to go into a show where i only have access to a network printer. I am running an IPC, so im not sure if this is possible. I also know that there is a parallel based (ancient!!!) printer, and the IPC has a parallel port . . .
Although another thought would be to just print from 3PC on my laptop . . . but is that possible while using it as another console on the network? or do i have load the show by itself?
