In most cases, you can downgrade console software by just using the .fpspkg installer. We will usually indicate in the release notes when we change something with the operating system that would require a full install or that would break show file compatibility. If a full install is required to upgrade between software versions, then it will usually be required to downgrade between those same versions.
