Library Version
I would like to ask if a feature can be made to make it possible to change the library that your showfiles uses. It is very frustrating to not be able to use newer librarys because your showfiles were made a long time ago. The data is in the console, but changing your show to use it isn't possible, so if newer fixture libary's come out you can't use them.
David Wetmore
  • David,
    We only increment the major revision number (the first number in the version) when we make significant architectural changes to the library that have the potential to cause compatibility problems or that depend on certain console software to function properly. This is why it isn't possible to merge libraries with different major revision numbers.
    Luckily, significant changes like this don't happen very often. We've been using the v4 library for more than 2 years now.
    Thanks.
