The best thing to do is to download MIDIOX and connect it to your console's output port. (www.midiox.com/). You can then execute commands and dump them to your computer.
The direct solution is their scoring software sends MSC direct via a USB->MIDI device. In the MIDI world, MSC is referred to as System Exclusive Messages (SysEx).
On the odd chance that their software can do MIDI notes but not SysEx then add a MIDI Mapping device to the link to convert the Note to MSC. www.midisolutions.com/prodepp.htm
Worst case, install some "show conrtol" software that you can program SysEx messages into and trigger from. There's free, and nearly free, software for doing this. www.showpromidi.com/
The thread that Quinn linked to does have some examples and a good description of the basic command format.
I'd be glad to explain the exact messages if there are some specific commands that you're trying to build. Can you tell me more about what you're looking for or trying to do?
F0 7F 01 02 01 01 XX 00 YY 00 F7 F0 7F - This header begins the message. 01 - The device ID of the receiving console. 02 - Indicator of an MSC message. 01 - Command format = Lighting. 01 - MSC GO command. XX - Cue number. See below. 00 - Delimiter between cue number and cuelist number. YY - Cuelist number. See below. 00 - Delimiter after cuelist number. F7 - Completes the command.
The cue number and cuelist number are represented by a series of ASCII key codes for each digit. The numbers 0 through 9 are represented by the codes 30 through 39. A decimal point is represented by code 2E.
So, a GO message for cue 91.5 on list 12 would look like this:
F0 7F 01 02 01 01 39 31 2E 35 00 31 32 00 F7
The cue number is 39 31 2E 35: 39 = 9 31 = 1 2E = . 35 = 5
I hope this helps. Please let me know if you have more questions.
You're welcome, Ross. It was great having the chance to meet with you last week. I'll chat with Brad about adding a MSC fundamentals section to the user manual. I think it would make a very useful appendix.
