couple of problems
Last week i did a show with midi timecode and i had a couple of problems.
1 two times I lost my timecode. I checked all the settings and there where correct. The strange thing was that I had still timecode on the other two Hog III with the same settings. After a Hard reset ( but the desk off) the timecode was back
2. In some cuelist I used a priority. If i want to change this it`s jumped to 50 or -50. Also sometimes if I had changed the priority to 30 and i closed the optie menu the fader shows still that the priority was on 10. I solved this to copy the cuelist and delete the originel. Or just restart my desktop.
3 Is`t possible to get a view that`s telling you how long it will take before the HOG III is finished with installing a full install
