Have I missed something, but I have tried to find a way to change the direction of a simple intensity chase created with effects generator?
I have 10 movers on the left side of the stage and 10 on the right side. I want to make an intensity chase which is running from the back of the stage towards the audience in paraller but I can't do it with the effect generator. Instead I have to make a cuelist and run it as a chase.
With some other consoles the effects are running in same order where the fixtures are chosen.
So in that case if I choose 1 through 10, then set the rate, size, offset with fan etc and next choose 20 through 11 and type the same values, I should have this effect built up quickly.
