Wholehog v2.2.1 Released!
We have today released new software for all current Wholehog products. Version 2.2.1 is a patch that contains many important bug fixes and enhancements. A new visualizer connectivity driver is also available. Software downloads and release notes are available at www.flyingpig.com
Please note the following information:
Ø Wholehog 3 console users: Version 2.2.1 includes some changes to system files that require using an ISO image for installation. A FPSPKG file is not available for this release. Performing a Full Install of v2.2.1 from an ISO will format the hard drive and erase all show files. To upgrade to v2.2.1 without erasing show files, hold the PIG key while the console is booting, place the CD with the ISO image in the drive, and select “Upgrade Software” from the boot menu.
o NOTE: The upgrade installation can take up to seven minutes and does not display a dialog during this process. Please wait for the console to fully reboot before attempting to cycle the power.
Ø
Hog iPC Users: When using Hog 3PC on Hog iPC, you no longer need to access the Hog iPC configuration panel for normal operations. The following items can now be accessed in the Wholehog Control Panel:
o Set time and date
o Touch Screen calibration and 3rd monitor enabling
