Saving user library to CD
I built a fixture library with the fixture builder application in the Hog3. The library is in the user library folder in the fixture library like usual. So, how can I save this library on a CD? Tried to do that with the Burn-CD application of the console, but cant find the single library file only the whole libraries. Any idea?
Jens.
  • Jens,
    When you create a library using the fixture builder, it is added to the show file that you are working on. You can backup the show file from the shows window (Setup -> Shows) and you can then merge this into other show files using the merge button that is also on the shows screen. When you merge shows, you have the option to merge individual fixtures and you can choose to merge other items (views, palettes, cuelists, etc.) if you would like.
    I hope this helps. Please let me know if you have any problems or other questions.
    Thanks.
