Blade flip
Hog3 has many features which can ease the pain of programming and cause I think everything is possible with software, this idea came to my mind.
Blade flip&rotate
For example if you have made something like this with blades of VL1000
/_\
it would be nice to be able to transfer the values easily from blade to blade so that the pattern turns 90 degrees or 180 degrees.
Does this make any sense?
Parents
  • Nice. That could be very nice with Lemur multi touchscreen :) ,
    but I think it needs a bit tweaking. I might be wrong, but I have a feeling there's fixtures on the market, which have blades/shutters going over 50% of the beam.
    But this discussion brought also another idea to my mind. A cycle button.
    It would be nice to be able to cycle parameters through fixtures with single button. Also a possibility to have a cycle FX would be also pretty cool.
    Like if you have 4 fixtures in color red, blue, green, cyan. After pressing cycle button you have cyan, red, blue, green.
Reply
Children
No Data
