ELO touchscreen - beeps only in system speaker
Does anyone know how to get the ELO touchscreen mouse beep to occur my soundcard? I have SoundBlaster Live sound card, but the beeps that the ELO touchscreen make are only heard through my computer's built in speaker. I can barely hear it and it would be nice to have the audio confirmation come through my PC's powered speakers.
Ross
  • Have you tried going into your sound properties menu in the control panel to make sure that the volume for your output is turned up. It usually looks like a slide fader. You also may want to look and see if the wave volume is turned up as well.
    Hope this helps....
  • thanks - i checked all those before posting. I build PCs all the time. This is really baffling. When I hook the touchscreen up to my laptop it works as desired. On my older computer - it sends the sound to this tiny PC speaker, but the rest of the windows sound go through the soundblaster.
    I think I will try installing a different piece of hardware and see if that fixes it. I have several sound cards laying around.
    Ross
  • Hey Ross,
    You ever find out the source of your sound issue?
  • No - I have never figured out why the touch screen sound only happens through the system speaker - which I can't even hear unless I am in my office.
    Ross
