Question...
Hey Guys,
I have 9 VL2000 in a show and they set as a Back line on the floor and i want to do an INT Efx from center to end.
so the efx shold be:
1 2 3 4 5 6 7 8 9
1 2 3 4 5 6 7 8 9
1 2 3 4 5 6 7 8 9
1 2 3 4 5 6 7 8 9
1 2 3 4 5 6 7 8 9
It's start with 1 VL2000 and continue with jumps of 2 VL2000 every time.
O.k. so i know the Hog for something like...4 years now and work with it almost every day and I Don't Know How To Do That !!!
Now that's a difficult question...let see if any of your geniuses out there can answer on that.
Amir
DANIX SYSTEMS
Israel
Parents
  • Amir,
    If I am reading correctly, you want to do an Intensity chase from ctr out to the edges.
    If so, you should be able to either build a chase that does it or you should be able to do it with the effects engine.
    For Effects Engine, you should be able to select Fixture 1-9 and select your intensity effect. Once the effect is the proper rate and size, you should be able to hold "FAN" and select "Center" on the tool bar. Adjust your offset and you should get what you want.
    I don't have a console in front of me, but this should get you close to what you want I believe.
    J
Reply
  • Amir,
    J
Children
No Data
