Hi guys I have downloaded the zip file and formatted the usb key via the console and when I re booted the system and pressed f8 as the console explains and I cant find where you can select the usb to load the new xpe image. If you could explain what I have missed that would be great.
Maybe you are pressing F8 at the wrong time. I just booted a Road Hog and pressed F8 a few times while the HES logo was on the screen (during the first showing of the logo). Then it would continue on through the boot process and display "press any key to continue" and I would wait. Right after that it shows a blue dialog box where I can choose the boot device.
Hi Brad THanks for that I keeped pressing f8 unit it worked. I cant work out when it exactly worked but It did work. Now the Roadhog is up to date and still going strong.
