As group are not (yet?) recorded in cue, it would not be the same. - pallette is recorded in a cue, so when values in palettes are modified the - palette would also be modified.
[quote=Marty Postma]Isn't this what SELECT then INVERT already does? Select Invert is only for those already in programmer.
I think - Group would select ALL other fixtures. I'm not sure how usefull this would be. Maybe it could be useful if it would select all other by type. Though making a group containing one fixture per type would select all other fixtures except fixtures in group.
and still I would like too see - color putting the fixture to opposite color in HS picker.
Yep...but I think you know it's not the same... Remdim doesn't select fixture already in 0% and doesn't work in blind. But like I said this isn't very important. Though, I like the idea that a feature invented should be taken to max and there should be more ways to intuitively use - key.
