NEWBIE QUESTION - using pallets
hi folks:
I know its something dumb im doing but i cant find it (prehaps not enough caffeine yet)
I have 2 studio spot 250s sitting on the stage for some effects for a show on wednesday. i take control of them and swing them to a positon that i want them to be aimed at. I dont sent any parameters other than position and intensity (so i can see where they are pointing) I select the lights and hit record {Position pallet 2) adn give it a name.
My understanding was then that as i was doing other stuff, i could set an intensity, and select the 2 spots from the group directory, and hit that pallete and have them swing back there but they arent moving -- what have i done wrong?
{about 15 minutes later} -- i just discovered if i select the position pallet and touch the pan or tilt wheels they will swing to where they were programmed to go
{update 10:12} -- must have been a board issue -- i rebooted the board and it works right now -- things are going swimmingly!
TIM
