I need some input on how I should set up my Hog3 network. Here's what I got...
Hog3 Console....DHCP server enabled, IP=172.31.0.1
DP2000 1......DHCP disabled, static IP=172.31.0.2
DP2000 2......DHCP disabled, static IP=172.31.0.4
All of these are connected via a Linksys 10/100 8 port switch (not router)
Then, also connected to the switch is a Linksys WiFi router. DHCP is disabled and static IP address is 172.31.0.9.
Hog3PC on a TabletPC.....WiFi adapter static IP address is 172.31.0.9
I'm looking for suggestions on how to improve the stability. I have recently had issues with the TabletPC's wireless connection running Hog3PC fine for a while, then losing connection and causing Hog3PC to quit.
I'm not sure what my setting should really be. DHCP, no DHCP?
