ENH: Fader level to follow actual faders
I would like to request that the fader level on the cuelists follow the ACTUAL fader.
For ex:
Take Cuelist 1 and put it on both the console and the wing on the same page. Raise the fader on the console and the "fader level" goes up on the list on the wing but does not show up on the console side fader.
I use a wing as a "remote" on the opposite side of the booth to have the audio person be able to trigger lists. It can get confusing as to which fader is up if it does not indeed follow the actual fader.
Jon
  • Hey Jon,
    Are you using a min-wing or a full x-wing? I have several lists like this on my mini-wing and on the console and I am almost certain I am seeing the blue fader bar change in both locations when positon is changed or flash key is used. I am seeing this on my H3PC system now for sure.
    I'll double check the console though when I am in front of my system again.
  • Marty...this is using the "small" playback wing.
    Page 1 on my console is copied on both the console and wing (ex. List 1 Fader 1 + Fader 1/1, List 2 Fader 2 + Fader 1/2...etc.) This is so that I have an exact copy of certain lists available to both the lighting and audio position.
    I have the "Wing" faders docked on Ext. Monitor 2 so the audio position can throw a switch and see the faders and cuelists.
    When I bring up Fader 1, the blue bar goes up on Fader 1/1...etc..etc... Maybe it has to do with having the dock in another location....not sure.
    Every list I have does this...
    So...perhaps for clarification...
    (1) Hog 3
    (1) DP2000
    (1) Playback wing
    (2) Ext. Monitors
    I'm heading to Chicago tomorrow...hopefully the show has a wing with their setup and I can test it further...otherwise, it will have to wait till Monday.
    Jon
