I'm using a lot of virtual masters and running them directly from the cuelist directory. One feature is missing and it could be easily built up.
So, when pressing the soft button of a cuelist on touchscreen a window should open on right touchscreen bottom line where you can adjust the level of the chosen cuelist with encoder wheel. It should work the same way as the GM works now.
This is useful for example for hazer, front lights etc. Now I have few cues in one cuelist like, little haze, a lot of haze and so on. If there would bean easy and fast access to adjust the level i could do with a single cue in one list.
Sulkkis
