Random requests
Would love a way to default the buttons and masters globally in preferences so that I don't have to edit the options of every cuelist to make it +go when off zero, and release at zero.
-An inhibitive master (or in this case a group master) should continue to assert even when a page change is made.
-Why can't I save the parked window to a view?
-A hit on a direct position palette should automatically select the lights recorded into it.
-To the hardware boys, the DVI to VGA adapter used for the third monitor gets right in the way of the left touchscreen on the IPC.. there has to be a way around this..
David M. Schulman
davelite@davelite.com
  • A few things that might help are...
    [quote=davelite]-An inhibitive master (or in this case a group master) should continue to assert even when a page change is made.
    You could try a few things here. 1- Put your Inhibitive Master on a template page so it is always there. 2- Try lowering the priority of other cuelists with these fixtures in them. 3- make sure you page-change behavior is set the way you want it under preferences.
    [quote=davelite]-A hit on a direct position palette should automatically select the lights recorded into it.
    Try holding down OPEN and touching the palette. This opens a new editor for said palette and will have all the fixtures recorded into it, you can then use a Select All to grab them all.
    Hope this helps a bit:)
  • if i put it on a template page, it takes up a fader on all pages, and i need all the handles that i can get..
    too many pushes just to grab the units..would be just as easy as a second button hit on the position palette to put the units into the programmer..
    Thanks for the reply
    Dave
  • Hey Dave,
    I hope you are doing well.. it has been a while!
    Regarding the defaults for faders and buttons... this is currently under development for our next release. Enhancment #4600 is its number.
    You are correct. I am looking into this now and will log a bug. I think it has always been this way for some reason. Actualy the view does remember the location and size, it just wont open the parked editor.
    What happens when you only want some of these fixtures? Enhancement #9260 suggests using Fixture+[palette] to achieve what you desire
    This will depend on the model/version/date of your Hog iPC and road case. Of course you can always remove the console from the case, but I know this is not always desired.
