Fader/Flash Button Bug
I know it's been mentioned before, but I wanted to make sure it didn't fall off the radar.
Take a cuelist and make it +GO off zero and +GO on flash
Push the fader up to activate, press the flash button and pull down the fader. The flash button will hold the level until released.
However, if you press the flash button first and then raise the fader, if you release the flash button, the list releases even though the fader is up.
Jon
