Hi, i want to change gobos at the same speed a fixture is moving, for example. Having a fixture in gobo 1 on stg. right and have it spin to gobo 4 as it pans to stg. left. It seems it always snaps to gobo 4 and then pans Thanks,
In the Cue-List set the Path to Linear. Now the gobo will scroll to the next one. You can aslo adjust this for just the gobo's by opening the cue, press Path, select the gobo-column(s), press Set and change the Path here. Press Update, and you're done! But you have to do this with each cue in the list to have the Linear Path in all cues.
If you always want to have your beam-palettes running a linear path you can change this in your preferences.
