What exactly are you trying to do? If you have any system that can output standard timecode, then you can feed this into the Wholehog system in several different methods:
1. MIDI timecode (MTC) through the console's MIDI port 2. SMPTE timecode through a USB Timecode Widget ( www.highend.com/products/controllers/usbltcwidget.asp ) 3. SMPTE timecode through a IOP ( www.highend.com/products/controllers/miditimecodeprocessor.asp )
You can also refer to the user manual and on-line help for further details about using timecode with the Wholehog system.
