(1809)Bug Report: Update not working as expacted
Date: 23.10.2007
Software Version and build number: V2.2.2 b1809 IPC
Number of displays:2
Connected USB Devices:Super Widged
Networked Devices:none
Detailed description of the problem including instructions to reproduce (if possible) and exact syntax used:
Have Patched 1008 RGB Leds 14 Cuelists with about 10 cues each.
If I correct Colorinformation on the leds in a active cue without blind (seeing the correct output on stage) after pressing update the information is not updated to all fixtures. I realized that merging information into existing cues may work in the most cases. (not all times but most).
I also realized a time lag between the two superwidgets. Try to build a effect running on dmx line 4 and 5. Looks perfect on stage but after recording it to a cue and playing back there is a seeable "offset" between the to lines
List any errors reported by the software:
none
Best regards Roman
