(b.1809) Bug Report: Adding Printers
V2.2.2 b1809
1 - Hog III
1 - DP 2000
Issue - Open the contol panel and open the printer window. Click on Add Printer. Once the Add Printer window opens, close the window using PIG+ BACKSPACE. This will crash the desktop and take out the process window. You have to pull the power cable and wait for the battery to die to restart the desk.
When the add printer window is open, you cannot close it using the close hard button. You are supposed to cancel out of that window to properly shut it down. Using the shortcut keystroke is what kills it. This is 100% repeatable.
