(2.2.2)Possible Bug Report: Changing Priority on Output Window
Date:10-30-07
Software Version and build number:V2.2.2 B 1809 H3
Number of displays: 2 external
Connected USB Devices: Playback Wing
Networked Devices: DP2000
Detailed description of the problem including instructions to reproduce (if possible) and exact syntax used:
With the Output Window on an external screen If I right click on the fixture type and click raise priority an error pops up on the screen with the option to abort, ignore, or retry. If I hit ignore or retry the error window just reopens, if I hit abort the screens go black and I loose all control of the desk I need to turn it off and wait for the battery to die, then restart. This did not happen with Desk Channels or Non Dimming channels.
I tried doing the same on a Road Hog running V2.2.0 b1738 and I do not get the error but it crashes the desktop process. Unique to the Road Hog if I click lower the priority it will work but not when I hit Raise.
List any errors reported by the software:
img36.picoodle.com/img/img36/6/10/30/f_H3Errorm_b62a3d1.jpg
Mychal John Maltbie
The MET
