Bug Report (1809) Go on +0
V2.2.2 b1809
1 - Hog III
1 - X-Wing
2 - DP 2000
2 - monitors
1 - Netgear Switch
Issue - If you have a list set as go on +0/release on 0, using the flash buttons do not fire the list.
I have two list set this way, one is a 3 step intensity chase, the other is an intensity chase built with the FX engine. Both are set to go on +0/release on 0. In the 3 step chase, pressing the flash button just flashes the cue that is at the top of the list, but does not start it running. On the FX list, pressing the flash button does nothing.
If the list is set to go on +0, then technically the list should go when the flash button is pressed sending the level to 100%.
