I think it´s alwas. The problem I have in every show. In my last show I have only 12 movinglights and 1 mediaserver on the desk. No wing. It´s maybe 50 ms delay. Also at fast effects the rate is not constant.
best Regards Marco
p.s. please loock at the file in the thread "groupmaster´s"
How did you arrive at the 50ms calculation? Was this with your eye and the rig? How was the data distributed? Are you able to see this directly with a DMX tester?
yes... with my eye. I said "MAYBE 50ms" But you can see it clear at stage and also in the outputwindow. I can not flash stricktly at a point. I have no DMX tester. It´s not only in one show, it´s always.
The reason I ask about a DMX tester or other equipment in the line is because we have many very picky LDs that are using flash keys all the time with the desk and they are very happy with the response. This is why I am curious how you are seeing a delay. Can you please send us your show file and also a detailed description of how your data is distributed to your fixtures?
Brad, my experience is that deskchannels flash´s at the point with no delay. all multiple channel fixtures flash´s with delay. I try it last week again on a touring show. I have some movinglights, a mediaserver and some led fixtures in there. the flash for the mediaserver and the led fixtures have a visible bad delay. then I try it on the weekend on a other show, where i have to flash some deskchannels. for this are no delay. the problem exist also on softwareversions until 2.2.2. and not only on special show´s.
