Tracking??
HI,
Is`t possible to get a tracking sheet ? So for example if you say fix. 1 thru 3 enter. You wil see fix 1 thru 3 in a sheet and here you can see in wich cue it`s used. also you can say i want only see the information pan,tilt and magenta so you can filter the information. If you do shows with 200,300, 500 etc movinglights than sometimes you don`t know if spot number 203 is used in 80 cues before the cue you want to make. if you have a sheet where you can see where this spot is used and with kind of information that will helps me a lot.
  • I'm also interested whats going on with tracksheet.
    My suggestion for tracksheet syntax would be FIXTURE or GROUP # OPEN. This would at least show in what Scenes, Palettes and Cues fixtures are used.
    For Cuelist tracking FIXTURE # LIST# OPEN or something like that could be nice...depends on what is thought as a mask...also Cue numbers could be used here to see tracksheet for certain cue range.
