Date: 11/18/2007
System: iPC
Software Version and build number: v2.2.2 (1809)
Number of displays: 3
Connected USB Devices: Touch Screens
Networked Devices: None
Detailed description of the problem including instructions to reproduce (if possible) and exact syntax used:
(See show in ODD/EVEN bug note)
Select view 'Phil 4'
Select view 'Phil Output'
In the output window, select SOURCES.
The fixture order will re-arrange itself.
PG
