HOG III MSC IN
I'm trying to setup hog III to take MSC commands from an Obsession II. I've checked all the settings on the Hog to make sure that both the console and the cuelist are set to receive MSC. I also checked out the event monitor - after reading some of the other posts - and made sure that the Hog was receiving show control. Here is an example of the syntax from the event monitor:
1501413493 [2] MidiController: SysEx Received
1501413493 [2] MidiController: Valid Realtime Midi SysEx [Device=1]
1501413493 [2] MidiController: Midi Show Control Received
1501413493 [2] MidiController: Parsing MSC Message [format=1]
1501413493 [2] MidiController: Cuelist control message [object=65535,cue=51isScene=false]
The Hog is currently not responding to this, or any, MSC commands.
Any suggestions would be much appreciated.
