Date: 11/20/2007
System: iPC
Software Version and build number: v2.2.2 (1809)
Number of displays: 3
Connected USB Devices: Touch Screens
Networked Devices: None
Detailed description of the problem including instructions to reproduce (if possible) and exact syntax used:
I have a third touch screen attached to an iPC.  Make and model is identical to the two ELOs in the case.
I am running into a problem where the console will not allow me to use the screen.  The third screen has the Flying Pig background graphic, and it responds to touchscreen calibration.  However, when I tap the button (in Control Panel) to enable the third screen, there are no resolutions available, and the screen does not become accessible for windows to move to.
PG
