Just a couple of things that i cant do with my IPC
First i would love to be able to export just my pallets and custom effects.
If export is not a viable option than the ability to change the default settings for effects.  There is no way to slide gently into a circle or other movement effect when it starts at 180 deg.  I would rather it start at zero for rate, and size.  I do mostly busking and often i am am unable to think 20 sec ahead of of real time.
last is there anyway to resize the third monitor so that i can take advantage of a larger monitor with more possible buttons.  Right now i just get bigger buttons and that defeats the purpose buying the big touchscreen.
thanks bunches
josh
