I can't seem to get two shows of mine to merge under the merge function. I run the wizard and select all the options to fully merge two shows. The wizard runs and then at the end tells me it has lost the server or something and then doesn't merge the shows.
I have two different shows and the artist is going to add some songs from the old show to our current show. Also myself and my LD are hoping to do some pre programming during a break coming up (in different cities) and want to be able to take the new stuff and add it into the show on the console. Is there something we need to do to make the merge work? Some sort of programming clean up? or renumbering of cues and lists?
Any help is greatly appreciated.
Justin
