hi i used i roadhog 2.2.2 when i start my desk 2 screen it's ok but when i start the roadhog software , all windows go on left screen after many reset it's the same. plaese help me
Check the bios battery. The link is to the IPC instructions but they are the same. www.flyingpig.com/support/BIOSBatteryReplace.pdf You will have to restore the BIOS settings after this. www.flyingpig.com/support/RoadHogBIOSSetup.pdf If you do a full restore (XPe 1.0.8) it will correct the settings for you. However if the battery is dead They will be lost on the next shutdown cycle.
