I'm using a Roadhog with software 2.2.2 and latest librarys. I have tried to make a library for a led parcan, but when I chose "build type" the console blanked the left screen and the right had the boot picture of a hog, only thing that worked was the trackball pointer. The second time the console just tilted, everything looked normal, but nothing worked. A few times have worked without problems. I discussed this with a friend of mine who is currently also using the same configuration, and he has had the same problem > he is using the led par with desk channels. I have asked your support for a library, as I have to have the convertion from hog2 ready on monday evening. The problem seems to appear when we change the strobe channels settings. If I choose the "not in use" option for this channel, there is no problem.
When you first open the fixture builder wait a couple of seconds before starting to do anything. I have crashed it if I select "New Fixture" immediately after the screen appears.
Before going into the Builder...
Clear the programmer.
Unpatch and Remove from the current show any versions of the fixture you are editing or trying to create.
And thanks for the tips! I got the library functioning by skipping the strobe channel. I've asked for a proper library and it is one its way, I believe!
