Cleaning Touchscreen
Hi Guys
What is the best way to clean the touch screens?
  • I use a lint free cloth with a cleaning agent specifically designed for LCD screens.
  • This is quoted from the ELO user's manual.
    The following tips will help keep your touchmonitor functioning at the optimal level.
    • To avoid risk of electric shock, do not disassemble the brick supply or display unit cabinet. The unit is not user serviceable. Remember to unplug the display unit from the power outlet before cleaning.
    • Do not use alcohol (methyl, ethyl or isopropyl) or any strong dissolvent. Do not use thinner or benzene, abrasive cleaners or compressed air.
    • To clean the display unit cabinet, use a cloth lightly dampened with a mild detergent.
    • Avoid getting liquids inside your touchmonitor. If liquid does get inside, have a qualified service technician check it before you power it on again.
    • Do not wipe the screen with a cloth or sponge that could scratch the surface.
    • To clean the touchscreen, use window or glass cleaner. Put the cleaner on the rag and wipe the touchscreen. Never apply the cleaner directly on the touchscreen.
    We have found that a damp lint free cloth works great. Sometimes our LD's like to eat doughnuts when they are fat fingering a show. To remove excess jelly-like substance, a little glass cleaner is needed. Oh, and I have never un-plugged from power before cleaning!:nono:
  • Using this for years, works perfectly.
    3M Microfiber Lens Cleaner
    www.drugstore.com/products/prod.asp?pid=82412&catid=110454&aid=334918&aparam=3m_microfiber_lens_clean&CAWELAID=61234878
